Design Buck Converter
Discussion in 'The Projects Forum' started by gusmas, Aug 2, 2011.
  1. gusmas
    Thread Starter Active Member
    Sep 27, 2008
    239
    Ok so this is my dilemma
    Is there a general way to start designing the buck converter because I have used a lot of formulas and when I simulate my outputs are not even close to what I desire. for now i just want simulations to work although in about a months time i want to build a buck converter but first I need to get my design procedure correct:
    So this is what I have so far:
    Input voltage(Vi): 38V
    Output Voltage(Vo): 10V
    Output Current(Io): 10A
    Fs = 100Khz
    Calculating Inductor Value:
    D = Vo/Vi
    R = Vo/Io
    Lmin = (1-D)/(2*Fs)*R
    L must be at least 10times the value of Lmin.
    Calculating Capacitor Value:
    assuming voltage ripple is 1%:
    1% of 10V = 100mV so therefore:
    100mV = (1-D)/(8*L*C*Fs^2)
    then making C the subject of the formula i get my Capacitor value.
    Am I going in the right Direction?
  2. mik3
    Feb 4, 2008
    4,846
    63
    Do it have to operate only in the continuous conduction mode or it doesn't matter?
    What is the minimum output current?
  3. gusmas
    Sep 27, 2008
    239
    Continues can't allow the inductor current to go to zero
  4. mik3
    Feb 4, 2008
    4,846
    63
    Ok.
  5. gusmas
    Sep 27, 2008
    239
    I would say 9.5 amps I can't affor to much current variations since the load requires a 10amp, 10 to 14V signal.
  6. mik3
    Feb 4, 2008
    4,846
    63
    What kind of load is it?
  7. gusmas
    Sep 27, 2008
    239
    Its a controller for hidrogen fuel cell
  8. mik3
    Feb 4, 2008
    4,846
    63
    L=\frac{Vin*(1-D)*D}{2*Ir*f}
    Assume Ir to be 30% of the maximum output current or less and caclulate Lmin.
  9. gusmas
    Sep 27, 2008
    239
    D = Vo/Vin
    = 10/38
    = 0.26315
    Calculating Lmin using your formula:
    Lmin = 12.28.
  10. mik3
    Feb 4, 2008
    4,846
    63
    OK.
    For Cout:
    Cout=\frac{Ir*D}{8*f*Vr}
    Vr is the output peak-peak voltage ripple
  11. gusmas
    Sep 27, 2008
    239
    Sorry Lmin = 12.2807 * 10^ -6
    Ok so for Cout:
    Assuming the voltage ripple is 100mV
    Cout = 9.8642uF
  12. mik3
    Feb 4, 2008
    4,846
    63
    Verify it with the simulation.
  13. gusmas
    Sep 27, 2008
    239
    Simulation indicates my Vo is 20V and my Current is 20 Amps.... My circuit is attached
  14. mik3
    Feb 4, 2008
    4,846
    63
    What is the duty cycle?
  15. gusmas
    Sep 27, 2008
    239
    The duty cycle is 50%
  16. mik3
    Feb 4, 2008
    4,846
    63
    Then you should get 19V.
    Set it to 23.6%
  17. gusmas
    Sep 27, 2008
    239
    Ah cool I see.I set the duty cycle to 28%, Althoug there is fluctuations in the voltage and current between 10.2 and 10.8. Is there a a way to make the ripple less? Although I don't think it will effect the fuel cell controller to much?
  18. mik3
    Feb 4, 2008
    4,846
    63
    It is possible to increase the value of the inductor or the capacitor. Increase that of the capacitor.
    Is it pure capacitance or does it model the ESR and ESL of the capacitor?
  19. gusmas
    Sep 27, 2008
    239
    no unfortunatly not. But ya like I said that should not effect the controller correct? Thanks a lot for the help you saved me a lot of time
  20. mik3
    Feb 4, 2008
    4,846
    63
    Increase the output capacitor to 100uF. If you build a real circuit you should check for the ESR of the capacitor.
    The ESR affects the output voltage ripple by Vr=ESR*Ir.
    Usually, if the ESR meets the ripple requirements then the capacitance is enough as not not increase the ripple too much. You might need a large capacitor with 3A of ripple current. You can increase the value of L to reduce Ir and thus decrease C.
