Design an Amplifier with 741
Discussion in 'Homework Help' started by msr, Mar 21, 2009.
  1. msr
    Thread Starter Active Member
    Jul 8, 2008
    62
    This is my first post here.
    I have to design an amplifier using just 741 op-amp(s) and resistors, with the following requirements:
    - closed-loop gain: 40dB
    - "3dB-frequency" (break frequency): 25kHz
    - input impedance: 47kOhm
    I'm looking at Microelectronics Circuits (Sedra) and trying to resolve this by using an inverting circuit (one op-amp and 2 resistors) but it doest seem to be a good choice. I can't acomplish all the requirements.
    Another question: how can I know the break frequency and open loop voltage gain of 741? (datasheet only mentions 1Mhz of unity-gain bandwidth)
    Any advices?
    Thanks in advance!
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    Look at the datasheet for a lousy old 741 opamp.
    Its output can go up to only 9kHz at 28V peak-to-peak.
    Its "break frequency" is only about 6kHz when its gain is 40db.
    Use a transistor at its input or another opamp to share the gain.
    Use a non-inverting circuit for the fairly high 47k input impedance.
