Design a terminal window.....
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
HI,
After progress in serial communication i want to try to make a window on computer for interfacing uC PIC16f877 to light led by pressing switch..
so, i want your suggestion that visual basic or processing which one to used as i have learned little bit processing software no idea how to interfacing extra tings in it...
thanks
tshuck
Joined Oct 18, 2012
3,534
The .Net framework makes things very easy for you. The serial port control makes interfacing easy. I have done one in C# within minutes with .Net.
There are plenty of places that explain the .Net framework, so a tutorial shouldn't be hard to find....
