design a circuit
Discussion in 'Homework Help' started by jstrike21, Jan 28, 2010.
  1. jstrike21
    Sep 24, 2009
    104
    Design a circuit that has a dc gain of 1/3 and a pole at s = -10. You may use resistors, capacitors, inductors and both dependent and independent sources in your design.
    I dont really know where to start can someone give me some equations or something to go off of?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    This is one possibility ....
  3. jstrike21
    Sep 24, 2009
    104
    thanks for the help I wrote out the transfer function and solved using the values and it worked for the two scenarios
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    Can you design the "dual" circuit using an inductor and two resistors?
  5. labhelp
    Jan 28, 2010
    28
    i haven't learned anything about that so i wouldnt know what to do
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Your point being ...?
