design 2 bit register with clear complement out and load parallel
Discussion in 'Homework Help' started by darksole, Mar 24, 2014.
  1. darksole
    Mar 24, 2014
    so I am stuck on this problem and cannot wrap my head around how I would implement this. I need to design a 2 bit register that can be operated according to the following function table
    S0 S1
    0 0 no change
    0 1 clear register to 0
    1 0 complement output
    1 1 load parallel data
    I believe that it will require two 2-1 multiplexers and two d flip flops. this is as far as i have gotten but am confused as how to continue. Can anyone explain how I would design this thank you.
  2. ScottWang
    Aug 23, 2012
    4,923
    776
    0 0 no change <-- don't care
    0 1 clear register to 0 <-- this function will be a problem, because the register only can count up from 00 to 01, so the 10 and 11 will never show up.
  3. Papabravo
    Feb 24, 2006
    10,338
    1,850
    You need a dual 4:1 mux and set the inputs to each mux as follows:
    0: Q output from the flip-flop for 'no change'
    1: 0 input to clear both flip-flops
    2: Q' output from each flip-flop to complement
    3: Parallel data Input
