Depletion mode transistor w/base/gate current?
Ian01
Joined Oct 15, 2006
I'm wondering if there are any depletion-mode transistors that allow a current through the gate/base/other control terminal?
I can't find any on the internet. I used the search function here.
n9352527
Joined Oct 14, 2005
1,198
As far as I know, all depletion mode transistors are of MOSFET type. These do not have gate current, like BJTs have. There would be current going in and out of the gate, but this is strictly for charging and discharging gate capacitance.
Any particular reason why you are looking for one?
Papabravo
Joined Feb 24, 2006
21,228
A JFET is a depletion mode only device. A MOSFET can be either depletion mode or enhancement mode. Neither one requires appreciable current into or out of the gate except for turn on and turn off where it helps to charge and discharge the gate capacitence.
If you are using an optocoupler then you could also use a bipolar transitor especially if you don't need the isolation and are looking for faster response and more reliability. Did you know that the CTR of an optocoupler degrades with age?
