dependent sources
Discussion in 'Homework Help' started by mary n., Jul 18, 2013.
  1. mary n.
    Jul 18, 2013
    Hi everyone!
    I am new to Pspice and I want to simulate a dependent voltage source like
    G 0 3 value{arctan(100*λ*V(2)}
    I used G/analog and connect its measuring between 0 & 3 nodes and the other to V(2) but the resulting netlist is
    G 0 3 0 2 1 not the desired one G 0 3 value{arctan(100*k*V(2)}
    can anyone help me what to do ?
    Thanks a lot!!!!
    PS : version of my pspice is 16.2
    And λ is a parameter that can be 1 or 10 dependent on condition
  2. WBahn
    Mar 31, 2012
    18,088
    4,917
    If you want to make a dependent voltage source, then why are you using a voltage-controlled current source?
    First off, your expression is missing a right-paren, but I'm assuming that this is a typo in your post.
    Second, you can't evaluate expressions and use them as node values, though there are some devices that will let you do something like this.
    It looks like you are trying to make a behavioral voltage source. This would be an E device using the VOL= or VALUE = parameter.
    Check this reference out: http://www.ecircuitcenter.com/SPICEsummary.htm#ABM
    mary n. likes this.
