Density of states
boks
Joined Oct 10, 2008
218
1. The problem statement, all variables and given/known data
We study a one dimensional metal with length L at 0 K, and ignore the electron spin. Assume that the electrons do not interact with each other. The electron states are given by
\(\psi(x) = \frac{1}{\sqrt{L}}exp(ikx), \psi(x) = \psi(x + L) \)
\(\psi(x) = \psi(x + L)\)
What is the density of states at the Fermi level for this metal?
3. The attempt at a solution
According to my book, the total energy of the system is
\(E = \frac{\hbar^{2}\pi^{2}n^{2}}{2mL^{2}}\)
why is this?
It's evident that k = n*2*pi because of the boundary contidions. I don't know what to do next.
blazedaces
Joined Jul 24, 2008
130
Are you sure this is the correct equation? According to those two equations, k must equal 0. That doesn't sound right...
And why isn't this wave equation dependent on time? I'll just ignore that i guess...
why is this?
Explain to me why k = n * 2 * pi according to the information you have provided.
\(E = \frac{\hbar^{2}\pi^{2}n^{2}}{2mL^{2}}\) has nothing to do with your wave equation. Look up the proof, as I'm sure it's in your book as well as all over the internet.
It has to do with schrodinger's wave equation and its time-independant solution.
-blazed
blazedaces
Joined Jul 24, 2008
130
\(\psi(0) = \frac{1}{\sqrt{L}\) = \(\psi(L) = \frac{1}{\sqrt{L}exp(ikL)\)
This yields
exp(ikL) = cos(kL) + i sin(kL) = 1
so
kL = n*2*pi
Ah, I see. Point taken.
So, is it exp(ikL) or exp(-ikL)? Otherwise, why is exp(ikL) in the denominator of the fraction?
Well, if this helps, the density of quantum states per unit volume of a crystal is given by (again, you can look up the proof yourself if you would like):
\(g(E)=\frac{4\pi(2m)^{3/2}}{h^3}\sqrt{E}\)
So for the fermi energy level you have to plug in the fermi energy for E.
Good luck,
-blazed
