demorgan problems
Discussion in 'Homework Help' started by eduk, Dec 7, 2005.
  1. eduk
    Dec 7, 2005
    hi there i am quite reforumlating this into demorgans law thanks in advance
    (All INVERTED)
    (a inverted) (b inverted) (c inverted) (none inverted) - -
    A.B.C + A.B.C + A.B.C + A.B.C
    thanks its for a 3 input alarm. If 2 or more inputs and on then the output is on
    thanks ed
  2. kantgetslicker17
    Dec 7, 2005
    6
    Could you make it more clear which one is inverted?
  3. kantgetslicker17
    Dec 7, 2005
    6
    [attachmentid=1021] I'm Assuming this is what you want whenever there's 2 input on, output is high.
    [attachmentid=1023] This is the answer I have for you, just learned in my class 2 days ago.
  4. kantgetslicker17
    Dec 7, 2005
    6
    Here's an explanation on how I got the answer:
    [attachmentid=1024] This is call K-Mapping which is covered in allaboutcircuits in Digital section.
    [attachmentid=1025] This is the output that you wanted. I place a 1 on 011,101,110, and 111. Then I had them all grouped up accordingly in pairs. So now we have 3 pairs.
    From there the answer is just simply: [attachmentid=1026]
    Lookup K-Mapping in Boulean Algebra in Digital.
