This circuit is used to demagnetize a television picture
tube each time the set is turned on. The coil surrounds the tube and is energized with an alternating current
that quickly decays to zero over a period of several seconds. Which of the following components would
you expect to find connected in series with this coil?
A. A step-up transformer C. A piezoelectric device
B. A Hall-effect device D. A PTC thermistor
I think its C, am I correct? Thanks for the help.
