Hi all, we know the conversion of delta connected sources into wye connected sources ie we have to reduce the delta voltage by a magnitude of √3 and shift the angle by -30°.
So far so good.
This works only when there is no internal impedance of the voltage sources. But if the each of the delta source has an internal impedance, then how to convert this system into a wye connected system of sources with internal impedance s ?? So confusing!! Any help on this topic will be much appreciated.
Thanks in advance
So far so good.
Thanks in advance
