Delta-Sigma Modulation?
Discussion in 'General Electronics Chat' started by ELECTRONERD, Jul 22, 2009.
  1. ELECTRONERD
    Thread Starter Senior Member
    May 26, 2009
    1,146
    16
    Has anyone heard of Delta-Sigma Modulation? I've never heard of it before. What is it?
    Thanks in advance!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. millwood
    Guest
    it is a way to convert amplitude information into a time information.
    it is basically a comparator that takes your input signal, and compares it against an integrated output from the comparator itself.
    the output has only two states: high or low. and it is how long it stays high / low (or its duty cycle) that carries the information about the original amplitude.
    aka, it is a "1-bit" adc.
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    It is a single-bit quantisation, pulse-code modulation of an analogue signal, which works around the principle of delta-modulation.
    A delta modulator will produce an output that reflects the difference in adjacent sample of the input values rather than their absolute values (as in other analogue sampling regimes). It uses a sigma-section which subtracts from the incoming signal, lets call it x, another signal we'll call x' - if the difference is positive the 1-bit quantiser gives the output +q and if the difference is negative it gives -q. The stream of +qs and -qs gives the output stream y[n] which is a time-representation of the incoming signal. The x' signal is derived from an integration of the quantised stream. You can recover the original signal (at least a very close approximation of) from the output stream by firstly integrating y[n] (which gives x') and then filtering through an analogue reconstruction filter - this the process of delta-demodulation.
    Delta-sigma converters work on this principle though are structurally different employing both 1-bit ADCs and DACs with the integration section positioned immediately after the sigma-section as oppose to in the feedback path. From a circuits prespective try the e-book: http://www.allaboutcircuits.com/vol_4/chpt_13/9.html
    Dave
