Delta sigma ADC with gain > 128
Vindhyachal Takniki
Joined Nov 3, 2014
594
1. I have application where I need to measure strain (quarter bridge three wire) of 120ohm.
2. This is power sensitive application so I am using small current to excite strain bridge isntaed of voltage.
As I can switch off current source when not required.
3. I am using 24 bit adc - ADS1248 with internal current source.
4. Is there any high precision adc with PGA > 128 ?
joeyd999
Joined Jun 6, 2011
5,283
As far as I know, no one makes a D-S A/D with gain > 128. And I use these kinds of parts often (most often, ADS1242).
You could drop your Vref to as low as possible (0.5V, I think) or add a high-quality instrumentation amp between the bridge and A/D.
Both solutions will add noise. You can average multiple readings to improve noise performance.
cmartinez
Joined Jan 17, 2007
8,253
Joey's right... most ADCs have an internal amplifier that works at up to a gain of 8, and after that they implement "digital scaling" which is nothing more than a specially filtered multiplication of the signal obtained from the gain-8 instrumentation amplifier.
joeyd999
Joined Jun 6, 2011
5,283
The PGA in a delta sigma is digital, but it's not "faking" the gain. In fact, the input referred noise level drops with increased gain.
I use the ADS1242 with 128 PGA, and it works quite well.
cmartinez
Joined Jan 17, 2007
8,253
I use an old model by Intersil, an HI7190. I found it difficult to program and use... I'm gonna take a look at that ADS1242 of yours, see if it's an improvement... thanks
