delta connected squirrel cage induction motor
Discussion in 'Homework Help' started by Nikoz121, Apr 23, 2015.
  1. Nikoz121
    Mar 17, 2015
    The following set of results was obtained for a delta connected squirrel cage induction motor with a line to line voltage of 400V. Calculate the efficiency of this motor, plot a graph of the results and explain your findings.
    Hello, I've got this problem and I've been able to work out the output power using the formula P= (2pi * Torque * speed) / 60 and I also think I have work out the input power but I'm not sure if I'm doing right since I am getting a very very low efficiency for each reading. I have used the formula P = sqrt(3) * I_L * V_L * PF.
    Is the efficiency suppose to be that low? Thank your very much for your help
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Were the measured power values taken on a per-phase basis?
