Hi I have the following question:
The following are connected in delta to a 600 Volt three-phase supply.
Calculate the current in line B:
Calculate the current in line C:
I have drawn out the circuit in delta form to try and understand where the current is going but without the neutral of a star system I am confused when using kirchoffs law.
I know that two of the currents are not in phase so I have:
A-B 20A /_ 25.85 deg
B-C 30A /_ 0 deg
C-A 40A /_ 25.85 deg
I can't use the formula I line = I phase X √3 as the loads are not balanced. So I am unsure how the current is distributed between the phases.
- A-B has a 20 Amp load with a power factor of .9 lag.
- B-C has a 30 Amp load with a power factor of 1
- C-A has a 40 Amp load with a power factor of .9 lag.
B-C 30A /_ 0 deg
