DELTA CONFIGURATION
Discussion in 'General Electronics Chat' started by TAKYMOUNIR, Nov 12, 2014.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
    IN SOME 3 PHASE POWER SUPPLY ,THE INPUT OF THIS POWER SUPPLY IS DRIVEN FROM 3 PHASE DELTA NOT WYE AND THE REASON IS THE DELTA CONFIGURATION HAS LESS HARMONICS DISTORTION THAN Y SO WHY THE DELTA HAS LESS HARMONICS DISTORTION THAN Y
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    because the other two phase windings are in paralell with the other winding. dosnt matter which winding yhou are talking about, the other two are in paralell, damps harmonics. in wye, they are not in paralel.
  3. wmodavis
    Oct 23, 2010
    737
    150
    Quit yelling TAK! Learn to use your shift key. When someone yells at me I just go somewhere else. Didn't even read your post.
  4. TAKYMOUNIR
    Jun 23, 2008
    351
    CAN YOU PLEASE EXPLAIN MORE LIKE CAN YOU DRAW SOMETHING IF IT IS POSSIBLE
    THANKS
  5. TAKYMOUNIR
    Jun 23, 2008
    351
    WHAT DO YOU MEAN?
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    Is your shift key stuck?
    Writing things in ALL CAPITAL letters is like shouting.
    Please do not do this.
    Bertus
  7. Dodgydave
    Jun 22, 2012
    5,147
    769
    in Delta the windings go across two phases,which means they are in parallel, where as Star/Wye they are in series across two phases.
