Dell Latitude D505 power brick.
Discussion in 'General Electronics Chat' started by ian field, Jul 9, 2015.
  1. ian field
    Thread Starter Distinguished Member
    Oct 27, 2012
    4,447
    791
    Recently I won a Dell Latitude D505 (pp10L) but no power brick (PA10 or PA12). It was probably discarded for a reason, so I'm not going to spend any money on it.
    Does anyone have a link to the power jack pin out and what voltage?
    If I get desperate enough, I might try charging the battery pack standalone, just to find out whether the laptop fires up at all. But after all the warnings I've given others about messing with lithium batteries - I'd rather avoid that if possible.
    Obviously a functioning laptop would make it worth checking prices for a replacement power brick.
    Thanks.
    Dr.killjoy likes this.
  2. MikeML
    Oct 2, 2009
    5,450
    1,066
    I have one.... It is a model HP-AF065B83, 65W, 19.5V @ 3.34A. Mine works with either 12Vdc or AC input (different power cords)...
    Triaxial plug. Pin is ? (I think no connection)
    Outer sleeve is -
    Inside of inner sleeve is +
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    the charging circuit is in the laptop. the brick is just a pwm switcher. the input voltage is marked on the case of the laptop beside the power jack. a lot of those were 18.5 volt input, but there was a range of input voltages they would work with.
  4. #12
    Nov 30, 2010
    16,665
    7,312
    I also "won" a Dell computer because the owner bought an off-brand power brick. Caveat Emptor.
    Proper brick = proper computer = I win.
  5. Dr.killjoy
    Apr 28, 2013
    1,207
    157
    I have a couple dell power packs laying around here but are U.S. voltage..
  6. Brownout
    Jan 10, 2012
    2,375
    998
    Dell power bricks include a serial chip that "talks" to the laptop. Without this chip, the batteries won't be allowed to charge. I learnt this when I knocked my laptop off the table, and broke the serial wire. Now, I'm using a power brick from an older Dell, works fine.
