Dell e1909w repair
captain fantastic
Joined Sep 5, 2012
Hi!
i had a problem with my monitor(dell e 1909w), when i was working suddenly the screen went black not completely black fade that i can hardly see the background and this will be solved by turn off the monitor 2 or 3 times!
so i open the monitor and want to repair it! when i was working on inverter tow of the regulator pillars connect together and a big sparkle happen!
i buy and changed that regulator but it not fixed!
what should i change to fix this monitor? is there anything spoiled on the inverter board that i should fix or change?
thanks!:)
bertus
Joined Apr 5, 2008
22,276
I have downloaded the pictures and uploaded them to the AAC forum.
The images where not shown as the hosting site is not appropriate over here.
Please post the images directly on the AAC forum.
See this section of the FAQ on how to do this:
Attachments and Images
Bertus
captain fantastic
Joined Sep 5, 2012
The monitor doesn't turn on at all now,i changed some of the smd resistors behind the board but in case that they all burnt i could not read them clearly so if anyone can help me replace them with correct ones it'll be great,as you can see in the pic half of my board where that the colored wires are doesn't have any voltage.
sorry for my bad english.
thanks
