Delimiter project - frequency divider problem
Discussion in 'The Projects Forum' started by Hrenowsky, Aug 14, 2011.
Thread Status:
Not open for further replies.
  1. Hrenowsky
    Aug 14, 2011
    Hi!
    First a little sum up of what i want to make.
    I've got a JDM vehicle that has a top speed delimiter at 180km/h.
    This is regulated by the speed sensor, which has a square freq pulse (see attached images).
    Now i found and built a circuit which divides the frequency sent from the sensor to the ecm by 2, but there is a problem, because the voltage on the output drops to 6V, this causes the ecm to register a fault (and turn on the mil warning light). I've attached a simulation of the circuit in multisim for reference.
    I've looked everywhere but did't find a solution, so any help would be greatly appreciated :)
    There is one thing else, i've heard of a circuit that sends realtime signals from the sensor to the ecm until it reads 170km/h then it just keeps sending the 170kmh signal regardless of the sensor reading, so the car can reach it's actual top speed. I've searched for this circuit, but have no idea what it's called or how to make it...
    Sensor at 10km/h
    Sensor at 50km/h
    Sensor at 100km/h
    Sensor at 170km/h
    Circuit sim
    Uploaded with ImageShack.us
  2. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,387
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    There will be enough sites where automotive questions can be discussed :
    Member selected automotive forums
    Bertus
Thread Status:
