Delaying a clock signal by 45 degrees.
Discussion in 'General Electronics Chat' started by PauloConstantino, Sep 3, 2016.
  1. PauloConstantino
    Jun 23, 2016
    265
    7
    Dear all,
    is there a way to delay a clock signal (translate its phase) by 90 degrees without just adding delay gates and so on ?
    I know that to delay the phase by about 180 degrees, you just pass the clock through an inverter, but what to do for 90 degrees?
  2. cmartinez
    Jan 17, 2007
    3,698
    2,766
    Squarewave, or sinewave?
  3. PauloConstantino
    Jun 23, 2016
    265
    7
    Square wave! :)
  4. cmartinez
    Jan 17, 2007
    3,698
    2,766
    mmmhhhh... not sure... mind posting a logic gate diagram?
  5. hp1729
    Nov 23, 2015
    2,088
    232
    By 45 degrees of what?
    An inverter does not "delay by 90 degrees" it inverts the signal with no delay.
  6. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Does the clock signal have a fixed frequency?
    How accurate must the '45' degrees be?
  7. PauloConstantino
    Jun 23, 2016
    265
    7
    Guys I am sorry. I meant to say 90degrees not 45 !!!!!!
    But its ok, I have solved the problem thanks a lot!!
    Here's a diagram:
    Ramussons, #12 and cmartinez like this.
