Delayed pulse 555
Discussion in 'The Projects Forum' started by WoodDuck, Oct 17, 2009.
  1. WoodDuck
    Oct 9, 2009
    14
    I've pieced together this circuit but I'm not sure if I've got all the connections right...
    Here's what I'd like it to do:
    When triggered with S1, U1 delays approx 10 secs before triggering U2. U2 then outputs a signal activating M1 for approx 3 secs before shutting of again.
    Does it look workable?
  2. bluebrakes
    Oct 17, 2009
    245
    7
    looks pretty good to me.
    one question though... why two 555s? why not a 556?
  3. WoodDuck
    Oct 9, 2009
    14
    Yeah, I might do that later - I wanted to make sure I was on the right track first.
    Does the switching transistor in U2 and S1 look right? Those are mostly the things I wasn't sure of. Also pin 7 on U1 - it looks like it's not connected to anything?
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Nope, your circuit has some problems.
    Try it like this:
    C5 is optional. It was mainly to enable the circuit to operate under simulation without having to add SPICE controls.
    If you leave C5 in, it will cause U1 to trigger when you first power it up.
  5. WoodDuck
    Oct 9, 2009
    14
    Thanks,
    I definitely don't want U1 to trigger until S1 is pressed so I'll leave it out.
    I assume c2 is 1 uF?
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    That's fine.
    No, it is 1 Nanofarad.
    1uF = 1000nF
    Conversely,
    1nF = 0.001uF
    There is also Picofarads.
    1uF = 1,000nF = 1,000,000pF
    0.001uF = 1nF = 1,000pF
    0.000001uF = 0.001nF = 1pF
