delayed monostable
Discussion in 'Homework Help' started by raffter, Jul 13, 2008.
  1. raffter
    Thread Starter Active Member
    Feb 28, 2008
    113
    Hello guys,
    need help :(
    kindly reffer attached image.... I have no idea HOW im going to make a delay with this... the 1 shot monostable, I could do... but the delay, clueless :confused:
    -Ralph
  2. theamber
    Jun 13, 2008
    318
    Easily you can use a 555 push-pull circuit that will produce push-pull pulses but they are not good square-waves and they are not a modified sine-wave. You could delay the startup of the oscillator.
    You can build a circuit with "presettable mark/space ratio" the mark and space are the high low ratios of the waveform.
    More info here:
    http://www.talkingelectronics.com/FreeProjects/555/555-P2.html
  3. raffter
    Feb 28, 2008
    113
    its NOT an oscillator...the input is manually triggered..like I said before, its a 1 shot monostable, BUT with a -delayed- output... :)
  4. JoeJester
    Apr 26, 2005
    3,401
    1,218
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Use two monostables, one for the delay and the other for your pulse.
  6. raffter
    Feb 28, 2008
    113
    ok.. BUT how do I wire this thing up? the 1 second delay..
  7. raffter
    Feb 28, 2008
    113
    GOT IT :)
    a long "delay" monostable + inverter + short "delay" monostable...
    BUT!!
    I still have minor problem, even with a 500mS logic "1" trigger only, IT STILL TRIGGERS... finding a way HOW to NOT accept trigger pulses below 1sec "1" input...
