Delayed Automatic On Relay
Discussion in 'The Projects Forum' started by epicfatigue, Feb 25, 2013.
  1. epicfatigue
    Feb 22, 2013
    27
    Hello everyone,
    This is my first post here,
    I drew up this circuit, i believe it is correct but before i set off on wiring it up i just wanted to double check with people that know what they are doing.
    I am attempting to create a time delay on relay, once the circuit has power then x amount of time it will close the relay and when power is gonethe relay will then open again.
    this is what i sketched up.[​IMG]
  2. sheldons
    Oct 26, 2011
    616
    101
    your circuit will work,but it could do with a few extras......have a look at this to give an idea how to use the 555 timer and you could always download a datasheet
  3. epicfatigue
    Feb 22, 2013
    27
    thanks is that a negative or a positive trigger on that circuit. ?
    Have you tested it?
  4. sheldons
    Oct 26, 2011
    616
    101
    yes that particular circuit has been built and tested many times and been used for quite a few different things with component changes to suit....the 555 requires a negative going trigger signal and the circuit around the bc547 etc provide an edge triggered signal for the 555
  5. epicfatigue
    Feb 22, 2013
    27
    what changes would i have to make to that circuit to make it a positive trigger or to only start when power is applied to the circuit?
    As my application requires a 5v trigger
  6. epicfatigue
    Feb 22, 2013
    27
    okay i believe i have it now, using my original circuit with a few things moved around and using a pnp instead of a npn it should work!
  7. sheldons
    Oct 26, 2011
    616
    101
    pnp......nooooo.....as it is the trigger signal is active hi-positive-to do the same with a pnp your trigger would be active lo....the op from the 555 is active hi and the transistor switches the gnd side of the load,if using a pnp on the op that would switch the supply side to the load but the 555 op would need to be inverted.....if you wish pin 2 could be triggered as shown.....that gives you a lo going trigger which then swings hi and stays there.....
  8. epicfatigue
    Feb 22, 2013
    27
    ah thanks for your help!,
    fyi the walking dead is awesome!
    i just spent all night reading a book on the 555 and i came here to post the good news i got it working!
    this is how i did it works flawless i used the resistor from pin 2 to 8 as a fast discharge works perfectly!
