Out2 is twice the length of Out1; up to 16 seconds longer.What is the purpose of out2?
There are four NAND gates in one package. They all need to have their inputs connected to something; either Vdd, GND, or another signal. They cannot be left disconnected, or "floating".and i assume that the U3d is connected in similar fashion with U3b and U3c.
Yes, they are all in the same IC package.And that all 4 U3's are part of the same 4093 Schmitt trigger?
Would i connect the motor in series through wire ?
Motor?
Is that what this is for? What are you trying to do with a motor?
You didn't mention that before now.
If you are hoping for a motor to run the same number of turns one way as it does the other way, it won't work like that.
You need to state what you want to do with the motor. This may have just been a big waste of time, and that is my fault for not asking more questions.
Whatever the power supply is, yes.The grounding can be taken as just the negative terminal of a battery pack?
That's OK - better to ask questions than simply not understand something.sorry for the amount of questions but im really trying to understand this, i don't want to just go away and build it without learning how it works.
As the circuit is now, there is no place where you could connect a motor. Since you didn't state the purpose of the timer, I did not provide any output besides showing that it could be done.
