Delay my delay [pic16f690 // pickit2]
Discussion in 'Embedded Systems and Microcontrollers' started by kelvinmead, May 15, 2011.
  1. kelvinmead
    May 15, 2011
    30
    hi, im having issues using the book pic in practice (which uses the 16f84 chip) and the chip that i got with the pickit2 the 16f690.
    now after bodging the book code (which is a million times easier to understand than the supplied "lesson" code (that leaves out minor items...) that comes with the pickit2.
    i have got the led on, and ive got it flashing, but to get the desired half a second delay in flashes ive had to call the delay routine 8 times for on and 8 times for off... this isnt useful, and is a bodge on how it is meant to be done... so my question is, how do i do this using normal integer numbers without massive duplications.
    Code ( (Unknown Language)):
    1. ;********************************************
    2.
    3. ; EQUATES SECTION
    4.
    5. TMR0        EQU     1                   ;means TMR0 is file 1
    6. STATUS      EQU     3                   ;STATUS is file 3
    7. PORTA       EQU     05H                 ;PORTA is file 5
    8. PORTB       EQU     06H                 ;PORTB is file 6
    9. PORTC       EQU     07H                 ;PORTC is file 7
    10. TRISA       EQU     85H                 ;TRISA (the PORTA i/o selection is file 85H
    11. TRISB       EQU     86H                 ;TRISB (the PORTB i/o selection is file 86H
    12. TRISC       EQU     87H                 ;TRISC (the PORTC i/0 selection is file 87H
    13. OPTION_REG  EQU     81H                 ;the OPTION register is file 81H
    14. ZEROBIT     EQU     2                   ;means ZEROBIT is bit 2
    15. COUNT       EQU     0CH                 ;COUNT is file 0C, a register to count events
    16.
    17. ;********************************************
    18.
    19. ;           LIST    P=16F690            ;PIC16F690 chip
    20. #include <p16F690.inc>                  ;PIC16F690 CHIP
    21.             ORG     0                   ;the start address is memory 0
    22.             GOTO    START               ;goto START
    23.
    24. ;********************************************
    25.
    26. ;CONFIGURATION BITS
    27.
    28.                                         ;REQUIRES 2X _ _ AND PLACED IN COLOUM 2... THANKS BOOK!
    29.             __CONFIG (_INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _BOD_OFF & _IESO_OFF & _FCMEN_OFF);copied from lesson1 low pin count demo
    30.
    31. ;********************************************
    32.
    33. ;SUBROUTINE SECTION
    34.
    35. ;1 Second Delay
    36. DELAY1      CLRF    TMR0                ;START TMR0
    37. LOOPA       MOVF    TMR0,W              ;read TMR0 into W
    38.             SUBLW   .255                    ;TIME-32
    39.             BTFSS   STATUS,ZEROBIT      ;check TIME-W = 0
    40.             GOTO    LOOPA               ;TIME is not = 32
    41.             RETLW   0                   ;TIME is 32, RETURN
    42.
    43. ;0.5 second delay
    44. DELAYP5     CLRF    TMR0                ;START TMR0
    45. LOOPB       MOVF    TMR0,W              ;read TMR0 into W
    46.             SUBLW   .127                ;TIME-32
    47.             BTFSS   STATUS,ZEROBIT      ;check TIME-W = 0
    48.             GOTO    LOOPB               ;TIME is not = 16
    49.             RETLW   0                   ;TIME is 16, RETURN
    50.
    51. ;********************************************
    52.
    53. ;CONFIGURATION SECTION
    54.
    55. START       ;BSF        STATUS,5            ;turns to BANK1
    56.             BSF     STATUS, RP0
    57.             MOVLW   B'11111111'         ;sets 8 bits as input (1)
    58.             MOVWF   TRISA               ;move to PORTA
    59.             MOVLW   B'00000000'         ;sets 8 bits as output (0)
    60.             MOVWF   TRISB               ;move to PORTB
    61.             MOVLW   B'00000000'         ;sets 8 bits as output (0)
    62.             MOVWF   TRISC               ;move to PORTC
    63.             MOVLW   B'00000111'         ;prescaler is /256
    64.             MOVWF   OPTION_REG          ;TIMER is 1/32 secs
    65.             BCF     STATUS,RP0          ;return to BANK0
    66.             CLRF    PORTA               ;clears PORTA
    67.             CLRF    PORTB               ;clears PORTB
    68.             CLRF    PORTC               ;clears PORTC
    69.             CLRF    COUNT               ;clears COUNT
    70.
    71. ;********************************************
    72.
    73. ;Program starts now
    74.
    75. BEGIN       BSF     STATUS,1            ;select register page 1
    76.             BCF     TRISC,0             ;make i/0 pin C0 an output
    77.             BSF     PORTC,0             ;turn ON C0
    78.             CALL    DELAYP5             ;wait 0.5 seconds
    79.             CALL    DELAYP5             ;wait 0.5 seconds
    80.             CALL    DELAYP5             ;wait 0.5 seconds
    81.             CALL    DELAYP5             ;wait 0.5 seconds
    82.             CALL    DELAYP5             ;wait 0.5 seconds
    83.             CALL    DELAYP5             ;wait 0.5 seconds
    84.             CALL    DELAYP5             ;wait 0.5 seconds
    85.             CALL    DELAYP5             ;wait 0.5 seconds
    86.             BCF     PORTC,0             ;turn OFF C0
    87.             CALL    DELAYP5             ;wait 0.5 seconds
    88.             CALL    DELAYP5             ;wait 0.5 seconds
    89.             CALL    DELAYP5             ;wait 0.5 seconds
    90.             CALL    DELAYP5             ;wait 0.5 seconds
    91.             CALL    DELAYP5             ;wait 0.5 seconds
    92.             CALL    DELAYP5             ;wait 0.5 seconds
    93.             CALL    DELAYP5             ;wait 0.5 seconds
    94.             CALL    DELAYP5             ;wait 0.5 seconds
    95.             BCF     STATUS,0            ;back to register page 0
    96.             BSF     PORTC,0             ;turn on LED C0
    97.             GOTO    BEGIN               ;repeat
    98.             END                         ;This must come at the end of your code
    i should be able to put a number / order the code so that tmr0 is .32 for half a second?
