Delay Circuit
Discussion in 'General Electronics Chat' started by robby991, Mar 25, 2008.
  1. robby991
    Thread Starter Active Member
    Dec 17, 2007
    79
    Hello, I would like to implement a simple circuit which when receives a signal, waits a certain amount of time before it sends out a pulse. How can I construct a simple delay circuit like this?
    How about: Input pulse --> resistor --> Capacitor --> Comparator--> output pulse once charging of Cap reaches input pulse
    would this work?
    Thank you.
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    robby991,
    The devil's in the details.
    What's the input signal: voltage, polarity, and timing?
    What power source is available: 1.5VDC, ,5VDC, 9VDC, 12VDC, 120 VAC, 220VAC?
    What's the delay time?
    What's the output signal: voltage, polarity, load, pulse width?
    Should be easy.
    Ken
  3. veritas
    Feb 7, 2008
    167
    You could use an astable multivibrator (either using an LM555 or schmidt trigger), and have the falling edge of the pulse trigger an instantaneous pulse.
  4. robby991
    Dec 17, 2007
    79
    Sorry KMoffett, I always forget these details when posting on these forums. Once receiving a positive voltage (3-5 V), I would like to wait about 1 ms before outputting the same voltage level. The pulse width is not important, anything will do. I have a DC power supply, so I can use anything between 1-20V.
    Veritas, I will look into the 555. Thanks for you help!
  5. project robot
    Mar 13, 2008
    6
    Does your circuit have to trigger on the rising or falling edge of you input pulse? Perhaps a decade or 14 stage counter would help. You can hold the reset line high until your input pulse is active then just pick your output pin.
  6. KMoffett
    Dec 19, 2007
    2,584
    234
    robby991,
    I think the hook here is "outputting the same voltage level". If I have this right: if the input signal is +3V than you want a +3V output pulse to start 1mS later, and if the input signal is +4.2V than you want a +4.2V output pulse to start 1mS later. 555's and logic chips will always output a fixed (mostly) voltage level.
    I don't have a solution, so will be looking forward, with you, to others' ideas.
    What's this used for?
    Ken
    An idea: Monostable (555 or logic) triggered by leading edge of input (as suggested) driving P-channel mosfet as a transmission gate. Input has to be there during the whole monostable cycle.
  7. robby991
    Dec 17, 2007
    79
    Project Robot:
    I don't think it matters, so we can just say on the rising edge of the input pulse. This should work fine.
  8. robby991
    Dec 17, 2007
    79
    Ken: I don't understand what you are saying, I am new to 555. In monostable mode, the circuit produces a single pulse when triggered. How can I add a delay before this pulse is generated? I know you can vary the period of the output pulse, but I don't know how to delay this pulse.
  9. KMoffett
    Dec 19, 2007
    2,584
    234
    You're right to be confused. :( "Two monostables" (two 555s or one 556). The first is triggered by your input signal. This provides the delay. The falling edge of the first monostable triggers the second one. This determines your output pulse width. What are you doing with the output pulse?
    Ken
  10. veritas
    Feb 7, 2008
    167
    You can do it with a single 555 if you don't care about your output pulse width; just connect the output of the 555 to the instantaneous pulse circuit I provided. If you need a high pulse instead of a low pulse, pass it through an inverter.
    The pulse width for the instantaneous pulse circuit is approximately R*C
  11. veritas
    Feb 7, 2008
    167
    I hope this is readable. This is what I'm envisioning you need.
  12. robby991
    Dec 17, 2007
    79
    Ken. The output pulse is going to the the control line to a tri-state buffer. Once the pulse is generated, it closes the switch, allowing "A" to pass to "B".
    Veritas. That is exactly what I need.
  13. KMoffett
    Dec 19, 2007
    2,584
    234
    And this Tri-state buffer is an analog switch?
    Ken
  14. veritas
    Feb 7, 2008
    167
    Glad I could help. I actually just used a very similar circuit in my senior design project, so the idea was fresh in my mind.
  15. robby991
    Dec 17, 2007
    79
    veritas, how does this instantaneous pulse circuit work?
    Ken. yes it is an analog switch.
  16. veritas
    Feb 7, 2008
    167
    It is based on the idea that a capacitor cannot instantaneously charge or discharge, so immediately after the input changes, the output will always be:
    Vout = Vin + Vcap
    Since output is tied to Vcc through a resistor, it will always return to Vcc as the capacitor charges or discharges through that resistor.
    When the input is low, the capacitor is charged to Vcc (Vcap = Vcc). When the input goes high (asssume Vcc), the output's instantaneous voltage tries to go to Vin + Vcap = 2 * Vcc, but the extra charge flows through the diode, so there is only a minor bump in the output.
    Since Vin is now equal to Vcc, the capacitor has no charge (Vcap = 0), so when the output goes back low, the output will follow the input (Vo = Vin + 0) until the capacitor charges again.
    I hope that makes sense.
  17. KMoffett
    Dec 19, 2007
    2,584
    234
    Robby991,
    So, here's a shot at a circuit that will work according to what I think you want:
    Analog input are pulses with varying widths (?) and amplitudes (3-5V)
    The delay between the start of the analog input and the start of the analog output is 1.0mSec. (adjust to exact with R4)
    The width of the analog output is fixed (by R7,R8,C5).
    The supply voltage for the 555's should be the same as your tri-state gate's logic.
    Problem?: If the analog input pulse is shorter than [1.0mS + the output pulse width] (see the forth input pulse), the width of analog output will be 1mS shorter than the input pulse width. :eek:
    Ken
  18. robby991
    Dec 17, 2007
    79
    Thanks ken and Veritas for your schematics. I have been reading up on 555 timers now to get familiar with them. Regarding your setup veritas, will this generate just one delayed pulse, or a pulse train? Meaning, when you trigger a 555 in astable mode with a single pulse, does that produce one output pulse, or does that act as a sort of "on" signal which turns on the 555 to continuously generate pulses?
  19. robby991
    Dec 17, 2007
    79
    Veritas, you mentioned having the 555 in astable mode. Shouldn't it be in monostable to generate just 1 pulse?
  20. 200729554
    Mar 31, 2008
    Using easy-soft software for modeling motor control circuits, how would you get the motor to run few seconds after the input pulse.
