Delay calculation for 8051
Discussion in 'Embedded Systems and Microcontrollers' started by teen devil, Mar 27, 2011.
  1. teen devil
    Thread Starter Active Member
    Apr 6, 2009
    i am new to 8051 and i want to generate delay ... i am having problem in caalculating delay ... can u please tell me the exact way for calculation..
    lets say i want to calculate delay of 0.1sec....
  2. teen devil
    Apr 6, 2009
    by the calculation of frequency and machine cycle the vaalue is 1.085x10^-6
  3. TierOne
    Feb 5, 2011
  4. PyramidComm
    Apr 1, 2011
    If you want to generate a delay without using one of the timers, your code won't be able to do anything else during the delay. If this is OK, use the following code:
    mov r7,#100 ;100mSec
    acall delay ;call delay subroutine
    delay mov r2,#230 ;2 cyc
    delay1 nop ;1 cyc
    nop ;1 cyc
    djnz,r2 delay1 ;2 cyc consume 230x4 + 2 instr cycles=922 cyc
    djnz,r7 delay
    If you are using an 11.059 MHz xtal, you will need to consume approx 921 instruction cycles per millisecond of delay. You could write a routine to consume 92,100 cyc, but that would only generate a delay of 100mSec. The delay subroutine consumes 922 cyc for each count in R7, so you have a subroutine that can delay between 1 and 255 mSec.
  5. HallMark
    Apr 3, 2011
    I think you are writing code in assembly language.
    Then first of all find the Machine cycles your Code needs you can find the cycles from the Datasheet for the particular instruction.
    Then you have to calculate the time taken for the cycle execution if the frequency is 11.0592MHz. 8051 uses 1/12 of oscilator frequency, So now frequency is 921.6kHz
    Now Cycle execution time becomes 1/f = 1/921.6kHz = 1.085uS
    now your Total Cycles * 1.085uS = your desired time.
  6. Nvade
    Jan 20, 2011
    Hi there.
    It is quite simple to create a delay using timer.
    As such oscillator frequency is 12(specifically 11.0592)MHz.
    So the clock frequency will be Xtal freq/12=1MHz(In case of 12MHz).
    i.e. pulse width=1μs.
    So operating timer in mode 1 (16 bit timer) gives a delay of .066s
    To generate a delay of ur demand create a loop that makes the timer to count in the multiples of .066
    i.e. for a single second delay, the loop needs to be executed 15 times and so on.
    I guess u can figure out the approach and convert it in assembly language.
    Anyhow if u need the code also, then i will give u that as well.
  7. teen devil
    Apr 6, 2009
    thnx guys for u help
