dehydrator and oven ?
Discussion in 'Off-Topic' started by Mathematics!, Mar 3, 2013.
  1. Mathematics!
    Thread Starter Senior Member
    Jul 21, 2008
    1,022
    I am thinking about making my own dried fruit/veg ... raisens , craisens ,...etc
    I am think about buying a dehydrator to make the process easier.
    But I was curious what the differences is between a dehydrator set on say 120 to 200 degrees and an oven set on the same setting.
    The only think I can think of is the volume differences of the two machines.
    Basically can one do the same with the oven as a dehydrator .... will the raisens come out equivalent in either one
  2. mcgyvr
    Oct 15, 2009
    4,784
    973
    how much do you think it will cost to run your oven for 3-4 days straight with the door open?...$$$$$$$$$
    The dehydration process requires air flow in addition to heat.
    buy a dehydrator.
  3. #12
    Nov 30, 2010
    16,663
    7,308
    Make a sort of solar collector such that a plate of glass keeps dust out of your food and convection keeps moving the humidity out of the chamber.
  4. Mathematics!
    Jul 21, 2008
    1,022
    so how long does a dehydrator run until the fruit or veg is done ?
    And what temperature range is it typically set at for a dehydrator or oven
  5. mcgyvr
    Oct 15, 2009
    4,784
    973
    A typical dehydrator has 1 setting..(on) and typically goes for a 3-4 days.
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    I would design you own, all you need is a box with a low wattage heater, and a fan for the airflow.
    If you want it to be really energy efficient then insulate the box well, and put a heatexchanger on the air inlet/outlet so heat is transferred and kept within the box.
  7. maxpower097
    Feb 20, 2009
    795
    388
    The oven will only go in 50 degree increments and is incredibly hard to maintain a contant temp of 150 or 120 thru the whole oven. If you were to buy a 10,000 dollar convection commercial oven then yes that would work. But a dehydrator not only circulates air, but can dial in a temp a lot better.
  8. JoeJester
    Apr 26, 2005
    3,393
    1,211
    Go for the dehydrator. Well worth it.
    maxpower097 likes this.
