Definition
Discussion in 'General Electronics Chat' started by Antonio, Nov 6, 2007.
  1. Antonio
    May 29, 2007
    27
    • What is the selectivity of a filter?
    • What is the mathematical expression for selectivity?
    :confused:
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    The selectivity of a filter describes the filters ability to pass frequencies of a specified range and reject all other frequencies that may/may be adjacent in the frequency spectrum. It is essentially a performance measurement for a particular filtered channel.
    It is expressed as the ratio of the signal strength of the frequencies passed against the signal strength of a similar frequency on an adjacent frequency which is filtered. It is typically written as decibels (dB).
    Dave
  3. chesart1
    Jan 23, 2006
    269
    LC circuits are often used as filters; the L/C ratio determines their selectivity. For a series resonant circuit, the higher the inductance and the lower the capacitance, the narrower the filter bandwidth. For a parallel resonant circuit the opposite applies.
    [reference: wikipedia]
  4. Antonio
    May 29, 2007
    27
    Thanks for ur answers!!!
    I read somewhere( a paper downloaded from net) that in Lowpass filter prototype it is the ratio of stopband to passband frequencies, but I am not very sure whether it is correct or not?
    Do anyone of you have any info for this??
