Define voltage and current needed to drive a solenoid valve
Discussion in 'General Electronics Chat' started by navidelec, Jul 12, 2014.
  1. navidelec
    Jul 12, 2014
    29
    I have a linear solenoid valve which I know Rs,Ls and Rp,Lp measured by LCR meter, I can say the only parameters which I have is the mentioned LCR data.
    How can I define the voltage and current to drive it?
    Where can I find a thorough explanations about solenoid valves?
    Thanks to your attention
  2. shteii01
    Feb 19, 2010
    3,507
    512
    Manufacturer datasheet?
    navidelec likes this.
  3. MaxHeadRoom
    Jul 18, 2013
    10,853
    2,524
    Is this a proportional type servo valve?
    Max.
  4. Alec_t
    Sep 17, 2013
    5,979
    1,138
    Unless you know the maximum power dissipation the solenoid can withstand you can only guess at the drive requirements :(.
  5. navidelec
    Jul 12, 2014
    29
    I don't have it, just the LCR inductance in P and S mode
  6. navidelec
    Jul 12, 2014
    29
    it's an electro-pneumatic linear solenoid valve
  7. MaxHeadRoom
    Jul 18, 2013
    10,853
    2,524
    Linear solenoid valve can cover a lot of bases?
    From two position to proportional, some details would be in order for any constructive help?
    It sounds almost like it is a magnetic set/reset type?
    If you don't have the manufacturers engineering data on it how did you hope to proceed in order to actuate it?
    If DC set reset, what is the resistance of the coil?
    Max.
  8. navidelec
    Jul 12, 2014
    29
    yes, such a normally-closed, direct acting valve
    Rp=800 ohm
    Lp=73mH
    Rs=198 ohm
    Ls=55mH
  9. MaxHeadRoom
    Jul 18, 2013
    10,853
    2,524
    Did you just come by this randomly?
    Does it not have any manuf or part number on it at all?
    Normally a magnetic latch relay has only one coil, if this has two then it appears you have the coil resistances, but AFAIK there are not too many mind reader members on this forum;).
    So for me personally to take it further I would need a little more info.:(
    A least a picture would be something!!
    Max.
  10. MikeML
    Oct 2, 2009
    5,451
    1,066
    Most pneumatic and water solenoids require ~2W to 10W to actuate them. I would just hook it to an adjustable DC power supply and slowly increase the applied voltage with some sort of pressurized fluid connected (water main?) an just see what happens.
    E=√(PR) = √(5χ198) = , so you could safely get up ~30V without hurting it...
  11. navidelec
    Jul 12, 2014
    29
    No, it's just an identify project of my university coarse and I should find the solution for doing these project in order to define a guideline.
    At all, thanks for your attention
    If you have an extra idea and a guideline for me please inform me.
  12. THE_RB
    Feb 11, 2008
    5,435
    1,305
    I disagree, there are certain commonalities in most solenoid valves and yu can do some simple tests.
    You can ramp up the voltage (and current) using an adjustable DC PSU, to find the pull-in voltage and current. That pull-in point is normally about half the rated voltage, or maybe 60% of it.
    Then increase it further until pull-in is fast and reliable under all conditions. That will do to run it.
    As a further test you can leave it activated continually and measure temperature rise to see if the coil cooks. ;)
