Define the ports of AT89C51 as input or output.
Discussion in 'Embedded Systems and Microcontrollers' started by MicroClub, Jul 21, 2009.
  1. MicroClub
    Jul 19, 2009
    I m using AT89C51 for digital clock, with external pulse.
    and in m using keil 2.23
    i m using assembly (ASM) files
    i want to set the port0-1-2 for parallel data, and port3 for serial data
    the problem is to define the port as input or Output
    Master Clock
    port0 for input ; Full 8 bit port
    port1 for output ; Full 8 bit port
    port2 for output ; Full 8 bit port
    port3 for output (to send serial data) ; Full 8 bit port
    Slave Clock
    port0 for output ; Full 8 bit port
    port3 for input (to receive data) ; Full 8 bit port
    please tell me how can i set the ports for input and/or as output
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The device's data sheet should give that information.
  3. adventtech
    Member
    Feb 10, 2009
    22
    To use the port pin as input, set pin to high. There isnt any separate port direction register in 89c51.
