Probably a silly question, but I changed the battery set-up for our camper from one group 24 to two group 27's in parallel. Something unexpected happened and I'm trying to understand it. The batteries were fully charged when we arrived at the campsite using a stand alone high quality charger, after 1/2 day, with only the fridge running, (LP heated ammonia with a small fan cycling frequently) the generic 4 led battery level went down to 3 lights. (probably < 12.7V)
Since we were only staying 2 nights, I wanted to watch the drain rate to estimate battery capacity remaining. We continued to use the water pump, lights and fridge, and even showered to use power. We never went below 3 lights.
When we got home (half hour away) I figured the truck would put some charge back in, but not much. I disconnected the battery from the camper and hooked it back up to the charger, and it showed 100% charge?? I know that the charge time for the final 10% of the battery is just as long as for the initial 70% in part because of the diminished charge rate. I expected a much higher drain since it dropped to 12.7V so fast.
I have drawn up a chart trying to show what I think is happening, is there a quick draw down (say...5AH available) to 12.7V and then 130AH available to 12.2V and then another 25AH before it dies?
Is this correct or am I missing something? I should have around 160AH available. Thanks, Mike
