Deducing polarity by looking at a circuit board.
FDBennett
Joined Jan 11, 2017
By looking at this circuit board, anyone tell me which of the contacts is positive (+) and which is the ground (-)? It is a standard two pole jack. I do not have the transformer and the poles are not indicated on the device housing. Thank you.
MaxHeadRoom
Joined Jul 18, 2013
28,682
If this is a barrel jack? Although the centre pin connection does not look in the normal place, but if this is DC input, the ground plane is usually the common (-ve). A & C. with B=+ve.
Max.
Marley
Joined Apr 4, 2016
502
It is actually impossible to say because there are no polarised components on the board. However, it is common practice to connect the ground plane to 0V so I would guess that the centre pin of the connector is positive. Also it is usual to have the centre pin of a co-axial power connector as positive. Not always though. I have seen equipment with the centre pin negative.
So assuming the ground plane is 0V and everything else is positive, then you can see the polarity of each of the three output connectors.
Careful though - because you can't be sure!
