Decreasing the range of ammeter?
Discussion in 'General Electronics Chat' started by onlyvinod56, Jan 3, 2016.
  1. onlyvinod56
    Thread Starter Active Member
    Oct 14, 2008
    362
    I have an analog ammeter 3A full scale.
    I want to convert it to 100mA full scale.
    I know how to extend the range but how to decrease it? WP_20160103_003.jpg WP_20160103_002.jpg
  2. dannyf
    Sep 13, 2015
    2,196
    417
    That black coil-like wire between the two terminals is of low resistance and extends the (current) range of the meter.
    Getting rid of it or replacing it with the right value resistance will get you the desired range.
  3. MikeML
    Oct 2, 2009
    5,450
    1,066
    Get rid of the internal shunt. Determine the sensistivity of the intrinsic meter movement (likely ~50mV or 1mA full-scale). Then calculate new shunt based on the meter sensitivity.
  4. spinnaker
    Oct 29, 2009
    5,062
    1,160
  5. wayneh
    Sep 9, 2010
    12,368
    3,224
    I think I'd use 300mA full scale if you plan to keep the same back plate. You'll remember it now but the next guy won't, and that next guy is probably you in a few years.
  6. spinnaker
    Oct 29, 2009
    5,062
    1,160
