Decreasing LM386 gain even more
Discussion in 'General Electronics Chat' started by cumesoftware, Sep 18, 2007.
  1. cumesoftware
    Thread Starter Senior Member
    Apr 27, 2007
    1,330
    11
    I recently found out that even having a gain of 20 (26dB), the LM386 amplifier will have problems of distortion due to clipping. The amplifier project is on the "Projects Collection" section, here: http://forum.allaboutcircuits.com/showthread.php?t=6204
    Is there a way of having a gain below 20? I heard rumors that are other way of setting the gain o this amplifier, but I don't know exacly how it is made. Just for reference, you can see the datasheet here: http://cache.national.com/ds/LM/LM386.pdf.It might be handy to see the schematic. I didn't figured out where are the positive and negative input inside this chip, since the negative input outside doesn't seem to be a true input.
  2. Distort10n
    Dec 25, 2006
    429
    I for one need to brush up on my transistors, rather than looking at them as switches. I am afraid I cannot give you a better answer than, 'it appears so.'
    On pg. 3 it mentions that it is only stable in gains 9 or greater so this implies there is a way to have a lower gain than 20. It also looks like the 'bass boost' circuit as explained on pg. 3 will be a good place to start with a lower gain of 20.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    In the LM386 schematic, let Rf be the resistor between pins 1 and 5. Let Rs be the resistance between the emitters of the diff amp (this is 1.5k, or 150 ohms if there is a cap between pins 1 and 8). The gain, by calculation and by simulation, is
    Gain = 2*Rf/Rs+1
    The gains, then, are actually 21 and 201, respectively (datasheet says 20 and 200).
    If you shunt Rf with another resistor (preferably in series with a DC blocking capacitor), you can lower the gain. You can use simple algebra to calculate the value, but keep in mind that the circuit may be unstable for gains less than 9.
  4. cumesoftware
    Apr 27, 2007
    1,330
    11
    Lets just say that putting a resistor between pins 1 and 8 will raise the gain. I experimented it myself. But I don't have the smallest idea of how to have a gain smaller than 20. However, like you, I think that the bass "boost" circuit is the key since does it's job by lowering the gain to 10 for high frequencies. I think, once the amplifier turns unstable if I lower the gain and use the bass boost circuit, perhaps the solution consists in dividing the voltage of the input signal.
    Good answer, but I forgot the detail on gain 9, and I want to use the "bass boost" circuit as well (of course, the "bass boost" circuit diminutes the gain by doing that). Is there any problem if I just limit the input voltage?
  5. Ron H
    Apr 14, 2005
    7,050
    657
    I'm not sure what you're getting at. Attenuating the input voltage will eliminate the clipping problem, but the amplifier will still be unstable if the gain (as defined in the equation I posted) is less than 9. If you are running the amplifier with pin 8 open, then the smallest resistor you can put in your bass boost circuit is 10k. The most bass boost you can get is about 7dB.
  6. cumesoftware
    Apr 27, 2007
    1,330
    11
    Precisely. Instead of decreasing the gain of the amplifier per se, I will keep it as it is and attenuate the input voltage. Then I will decrease the gain of the input stage to less than 1 (since it was 1 in it's original state - pot R1 at it's maximum). I wan't to avoid clipping at many costs, and not follow the example of some commercial amplifiers.
