this isn't a homework question, i have found this question in the past examination papers of university so i've decided to solve it, i have already designed an 3x8 decoder and now i need to convert it into 5 bit decoder, but i have no idea how to do it.Hello,
Is this a homework question?
What have you done to solve the problem?
Bertus
please elaborate, i didn't understand you.well, here is one solution.. suppose you need to decode a 5bit data ABCDE, then you can use the following attachment. Well, its just a schematic.. the diagram is not proper, but i guess it will be sufficient for you to understand. I made it in a hurry.
P.S. The enable 'EN' pins of the decoders are used as a means of selection.
Thread starter | Similar threads | Forum | Replies | Date |
Attiny1606 burning out when connected to a drv8251 | Digital Design | 3 | ||
K | Z80 address decoder | Digital Design | 5 | |
LED Ribbon-Spec VS Reality | General Electronics Chat | 8 | ||
SRAM COLUMN DECODER | Digital Design | 0 | ||
Why NEC IR remote control decoder does not work | Microcontrollers | 2 |
by Robert Keim
by Jake Hertz
by Duane Benson
by Jake Hertz
