decoder(4-16)(help me)
Discussion in 'Homework Help' started by diluka wittachchi, Apr 14, 2010.
  1. diluka wittachchi
    Apr 14, 2010
    help me.......:)
    1. Construct a 4x 16 decoder by using two 3x8 decoders. (use only the block
    diagrams)​
    2. Draw a block diagram of a D flip-flop and explain its functionality as a 1 bit​
    memory unit.
    3. A memory consists of 16 rows of 4bit cells. Each cell can be addressed uniquely
    by a 4 x 16 memory address decoder. This memory has a RW (Read-Write bar)
    control to activate read write cycles. Draw a block diagram to illustrate the
    memory module having one address bus (4 bit) and one data bus (4 bit). All other​
    necessary control signals must be present.
    4. According to your diagram given in (3), explain how you would store a 4 bit
    number in a given address and retrieve a number already stored in a cell via the​
    data bus
    thank........:)
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Why don't you attempt 1 & 2? Those should not be very hard. After that, see if 3 & 4 aren't easier to see the solutions to.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Why do you keep posting the same question over and over?
