Decoded Based D/A Converter
Discussion in 'Homework Help' started by RdAdr, Nov 27, 2015.
  1. RdAdr
    May 19, 2013
    214
    I want to simulate in LT Spice a decoded based D/A converter like the one shown in the last image.
    So I decided to use both NMOS and PMOS like in the first three images (green is for output). So, in the last image, if b3b2b1 = 000, then the last row has all 1s, and thus the output voltage is 0V. In my case, I used PMOS that conduct when 0 are applied on their gates.
    And the voltage reference is 8V. So the voltage change when one LSB changes should be 1V.
    So for 000 I should obtain 0V, and for 111 I should obtain 7V.
    But when I simulate, for 000 I obtain 1.2V, and for 111, I obtain 1.4V.
    (for logical 1, I use 5V, and for logical 0, I use 0V).
    What is happening? My experience with analog design is very bad.
    When the transistors conduct, they have Rds = 0.002 ohm. The used convention is b1b2b3, where b1 is MSB.
  2. RdAdr
    May 19, 2013
    214
    I figured it out. I connected the transistors incorrect. I mirrored them and it works. The source should be to the right, not to the left.
    But it works only for 000,001,010,011. Then it saturates at 3.6 V.
    LE: I figured it out. Some transistors were entering the saturation region. For vgs = 10V instead of 5V, it works. But it seems much 10V.
