Decibel help
Discussion in 'Homework Help' started by c2morg, Feb 4, 2004.
  1. c2morg
    Feb 4, 2004
    hi everyone, im stuggling to keep my head above water in the course im doing, hope you can help !
    the questions goes - oh and im not looking for an answer, that will get me no where, but if someone could walk through it, that would be amazing !! ;)
    "Calculate the voltage measured across a 600 ohms load for power level of 0dBm"
    Im ok with working out directly each of ohms laws, and pretty ok with minor decibel stuff, but I just dont even know where to begin with this !
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Are you familiar with:
    Votage Ratio in dB = 20*log(base 10)[V1/V2]
    I am trying to remember whether the voltage ratio is taken as a reference to dBw or dBm, at which case you would have to convert from dBm in your example, to dBw.
    For 600dBm:
    dBw = 10*log(base 10)(0.6) = -2.218 dBw
    It is along time since I did this so I'm a little rusty :blink:
  3. c2morg
    Feb 4, 2004
    cheers m8
    been taking a stab at it, i remember the formula
    right
    remember that P= V2 / R (voltage squared) / resistance
    swap it too v2 = p x r power X resistance
    uve got the resistance ®600
    times
    power(p) 1mw-(reference) (0dBm is equal and a referance to 1mW remember!)
    =0.6v
    square routed=.775v
    anyone verify im completly wrong and dave is right ?
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    I'll go with your answer c2morg, I think I'm venturing up the wrong tree with my response. And I can't see a problem with your calculation.
    Good effort :D
