decade counter
Discussion in 'Homework Help' started by Energetic, Feb 23, 2011.
  1. Energetic
    Jan 3, 2011
    33
    My task is to design a circuit on multisim which will count from 0-9 on a 7 seg CA display. I am going to use a 555 timer chip at 1Hz and have ben advised to used a 74LS47. Also should include a latching facility.
    Please assume i am keen to learn but am a complete idiot (fully qualified electrician) when it comes to electronics.
    i have attached what i have so far. (embarrassingly little)
    Any advice on where to start would be much appreciated.
    Thanks....
  2. n1ist
    Mar 8, 2009
    171
    16
    Look at the data sheets for the chips. They will tell you what each pin does. Years ago, the common lineup was a 7490 counter feeding a 7475 quad latch feeding a 7447 decoder.
    There are a bunch of circuits out there; google "555 74ls90 74ls47" to find some.
    /mike
  3. Energetic
    Jan 3, 2011
    33
    Thanks for the tip, i have had a go and have attached it below. It looks good (to me) but still doesn't do anything... Any advice on what's wrong would be great!!!!
    Cheers...
  4. jepoy
    Oct 1, 2010
    15
    the problem might be on the clock pulse.
    try using this scheme to get the 1Hz pulse.
    and I think pin 7 and 10 are not connected.
    I dont see no "dot".
  5. Energetic
    Jan 3, 2011
    33
    Thanks! The clock is now working. I have a nice pulse coming out. Sadly the rest is still not working... nothing on the display...
    Below is my latest effort...
  6. Energetic
    Jan 3, 2011
    33
    Any ideas, anyone????
  7. Energetic
    Jan 3, 2011
    33
    Sussed it, the 3,4,5 on the 7447 had to be tied high. counting away now...
    Thanks for the help guys...
