Hi guys I am building a spark-gap transmitter, without the Antenna, according to the diagram that is attached below.
I have used C1=C2=4700uF, R=10K, L=2.16 mH, Frequency=50Hz. My supply voltage=12 Volt.
But I am NOT seeing any spark. I have tested the voltage of the Capacitors. Voltage across C1=12 volt, C2 is 0 volt. Do you have any idea where did I make the mistake?
