I've made the audio filter circuit shown on a breadboard and it works fine. Now I've built and soldered it on a veroboard and it's not working - the sound is coming out clean with P3 (the dual pot) affecting the volume, not the frequency, and the resonance pots are doing nothing.
I've been through a few debugging steps, some several times, and I'm not sure what to do next. So far I have:
I am bit stumped by the error and how to debug it - if there was no sound I would check along the circuit to see where it was getting to. I don't know what might be causing there to be no effect.
I could have a false positive on a check, but before I test everything again it would be great to hear your suggestions of any other tests I could do and general thoughts about how to debug this circuit. I'm quite new to this - this is my first soldered board - and I'm looking to learn how to approach this kind of problem logically, rather than just checking everything again and again. Where would you start?
Thanks everyone,
Oggz
n.b. I haven't built the capacitor bank on the veroboard - seems an obvious thing to leave out at the start and add later.
- Checked the veroboard layout correctly follows the schematic
- Checked all resistor and capacitor values on the veroboard
- Checked all continuities and breaks on the veroboard (and re-soldered a few connections)
- Checked all power and ground points on the veroboard. All are connected properly.
- Checked the inputs and outputs to the op-amp. All are within a few millivolts.
Thanks everyone,
Oggz
