Hi, I have a circuit board with a 4-channel op-amp that is amplifying a signal using one of the channels. I'm feeding the amplified output to an Arduino and using an external interrupt to find the falling/rising edge.
But I'm getting bouncing on the edge as there is noise in the amplified signal. The signal is a sine wave between 0.1hz to 30hz or thereabouts.
I'd obviously like to eliminate the bounce, and I'm assuming I can setup a Schmitt trigger using one of the extra channels. The amplified signal ranges from about 0.5v to 3.5v, and I already have a voltage divider at 2.5v on the board that I can tap into.
How would my debounce circuit look like? And I'm assuming I need a capacitor-resistor pair that would have to match my sine wave frequency range to debounce it just right?
