Deboo INtegrator ( in Low Pass Filter)
Discussion in 'The Projects Forum' started by mokong, Nov 13, 2011.
  1. mokong
    Oct 14, 2011
    6
    I am trying to use a deboo integrator on my low pass filter because I am using a single supply for my op amp for my project. Can anyone know how to implement the deboo integrator on my circuit to avoid clipping and without affecting the frequency response. Thanks for any help.
    here is the link for my circuit, frequency response, and AC transient:
    circuit: http://imageshack.us/photo/my-images/94/des3q.png/
    AC: http://imageshack.us/photo/my-images/257/wave3w.png/
    Frequency: http://imageshack.us/photo/my-images/855/fre3.png/
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Greetings mokong,
    Please discontinue your practice of starting the same thread multiple times. It confuses those members who may be trying to help you.
    Be patient, it takes some time for an interested member to formulate a response to your question.
    hgmjr
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The LMx24 series is not an RRIO opamp (rail-to-rail input-output). It's common mode range includes ground, but it is limited to about Vcc - 1.5v. You are seeing clipping at about Vcc - 1v, which is better than what the specifications call for, your actual mileage will probably be worse.
    If you want to eliminate the clipping, then do at least one of:
    1) Reduce the amplitude of your input signal voltage to keep it within the common mode range of the opamp.
    2) Increase Vcc to 6.5v or higher; at least 7.5v suggested, and increase the offset of your input signal by 0.5v.
    3) Replace the LM124 with an opamp that is RRIO.
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    The circuit has a single supply and all the opamps have their inputs biased at ground so the output is a rectified signal, not as shown.
    The input must be biased at about half the supply voltage.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    No.
    The OP's input is a sine wave with an amplitude of 2.4v and an offset of 2.5v.
    They didn't show the 2.5v offset in the simulation, but it must exist, or otherwise they would not get any output.
    I more or less replicated their output in LTSpice; except the LM324 model I used is a bit closer to what the specs call for; the output was clipped at ~ 3.6v instead of ~4v.
    I used an opamp symbol with the inverting and noninverting inputs swapped; unless you happen to have a symbol called LM324a, LTSpice will complain.
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    I mentioned the missing input offset because it is not shown.
    The circuit will produce a clipped output with the negative-going parts missing (rectified).
