Death of a soldering iron
Discussion in 'General Electronics Chat' started by magnet18, Feb 12, 2011.
  1. magnet18
    Thread Starter Senior Member
    Dec 22, 2010
    1,232
    125
    Has anyone ever had a radio shack soldering iron just die?
    like, it was working fine, i turn off its power strip, i come back and it doesn't get hot.
    Its not the strip, and its not shorting out anywhere because it would get hot in that area, so I'm confused. I thought these were the simplest things ever...
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Yep. I keep spares.
  3. magnet18
    Dec 22, 2010
    1,232
    125
    OK, I have 2 now, one with a broken tip that cannot physically be removed, and one that up and died spontaneously.
    both lasted about 2 years
    Are there companies that make these better than radioshack for a similar price?
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    How much did you spend? I stopped using RS soldering irons, but in my early days they were under $2 each. I used a file to recondition the tips, something that is not needed with a good iron.
  5. magnet18
    Dec 22, 2010
    1,232
    125
    I think they're $10 ish now
    What do you use?
    Id like something that will last...
    I just realized that I now have pretty much absolutely nothing to do.
    I guess I could read through all these tabs that have been bookmarked for a rainy day...
  6. magnet18
    Dec 22, 2010
    1,232
    125
    So, does anyone have recommendations on soldering irons/stations?
  7. marshallf3
    Jul 26, 2010
    2,358
    201
    Weller WP-25 or better the WLC-100 - either last forever.
    magnet18 likes this.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    I got one of those for Christmas, it has a very durable tip, though I may have to buy a finer one.
  9. nerdegutta
    Dec 15, 2009
    2,565
    806
    I got one broke, one 100w I do not use, one 30w in spare and this for daily use:
    The tip is removable, and I grind it sharp from time to time.
    The 100w I was thinking of modifying so I can use it to heat up the etchant liquid I'm using. It's just a preliminary idea witch is growling very slowly.
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    Velamans's tips are good quality, if they'd pay a bit more attention to the base they might have something. I had one go out after a year ($25), then something blow and stink in the second unit after a couple of weeks, although it kept on working.
  11. kubeek
    Sep 20, 2005
    4,689
    806
    I use a Solomon like this with DIY regulator and it never failed on me, just had to change the tip once.[​IMG]
