DC Voltage sensing using lv-25P
Discussion in 'The Projects Forum' started by Navaneeth1285, Mar 19, 2015.
  1. Navaneeth1285
    Mar 19, 2015
    8
    hi,
    i tried to sense 80 V dc using lv-25p, i initially tried for voltage value of 10V.but i am not obtaining voltage on the secondary side,
    primary side resistance is 10k ohm 10W, and my secondary side resistance in 150 ohm, i designed them to obtain a voltage of 3V on the secondary side.
    i tried varying the input but there is no change in the secondary side, also my dso is showing negative value..??
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    Diagram please...we are not psychics.
  3. Navaneeth1285
    Mar 19, 2015
    8
    i also grounded the secondary side with the +/- 12 V supply
  4. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Wired as shown, the primary current should be 8mA if the sensed voltage is 80V. So far so good.
    If I understand the datasheet correctly, the secondary current should therefore be 8*1000/2500 = 3.2mA, resulting in 0.48V across the 150 Ohms. How did you get the 3V figure? If you get 0V, either there's a wiring error or the IC is dead/fake.
    Edit: Looking at the datasheet again, although the conversion ratio is stated to be 2500:1000, the nominal primary and secondary currents are 10mA and 25mA respectively, implying a conversion ratio of 1000:2500. Something is inconsistent :confused:. But that ratio should give 20mA secondary current and hence 3V across the 150 Ohms, as you said.
  5. Navaneeth1285
    Mar 19, 2015
    8
    hi,
    how can i test the LV25p to find whether iis working or not..?
    is there any specific method to do so..?:)
  6. R!f@@
    Apr 2, 2009
    8,785
    771
    Nope ..you have to build the circuit to test.
