dc voltage regulator 130 volt to 28 volt
Discussion in 'General Electronics Chat' started by thallmon, Sep 27, 2010.
  1. thallmon
    Sep 27, 2010
    5
    Hello every one. need help I have searched just about every electronis web site and have had no luck on this. I sure could use some help. Thanks
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You didn't say how much current you need at 28v.
    If it is very low current, there are a few linear regulators that you might use.
    If it's anything over 50mA or so, you'll need to use a DC-DC converter circuit, which will require the use of inductors and/or transformers and suitable ICs.
    thallmon likes this.
  3. thallmon
    Sep 27, 2010
    5
    Thanks for the reply. I will need at least 7 amps.
  4. marshallf3
    Jul 26, 2010
    2,358
    201
    Too bad it starts out as DC, that's going to make it more difficult but a switching regulator will do the job.
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
