DC Voltage Regulation with High current
Discussion in 'The Projects Forum' started by Jonnap2000, Oct 7, 2009.
  1. Jonnap2000
    Oct 7, 2009
    7
    Hi all,
    I have a project where i need to regulate the voltage from a non regulated Power Conditioning Unit from 35 V down to 28 V.
    The input to the PCU is 435 V AC, 3 phase with a 50 A circuit breaker from the wall out put.
    The output from the PCU is aprox 35 V 300 Amps. This is connected to a military vehicle slave socket (NATO).
    We would like to regulate the output to 28 V, 300 Amps with as little tolerance as possible and a surge of 600 A. The PCU will be used to run the military vehicle when the main engine and alternators are not running.
    Thanks for your help.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Sounds like a supply for one of the Transformers, or your personal tank.
    A 300 amp regulator is not easy to come up with, especially when it's regulating a regulator. Do you have a schematic of the PCU? The circuitry can handle the current, so altering it to output a lower voltage might be a better approach.
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    You should be looking for a commercial 3 phase AC powered supply that puts out a regulated DC voltage directly. At these power levels, this task is beyond a homebrew solution.
  4. R!f@@
    Apr 2, 2009
    8,791
    771
    35V-28V = 7V @ 300A. The series regulator will have to dissipate 2.1KW.
    I donno what can handle that power, but the latest trench FET's or IGBT's.
    Still 2.1 Kilo watts as heat is still unthinkable for series regulator, you need to go for switch modes.
    Beenthere suggested the best method.
    Rifaa
  5. Jonnap2000
    Oct 7, 2009
    7
    Hi Beenthere, i have a circuit diagram of the PCU if that is what you mean. The publications for the PCU are hard to come by as it is a one off "green box"
    Can you elaborate on the use of a switch mode power supply. I am a little rusty when it comes to power management.
    Cheers
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Try posting the circuit diagram. If that can be altered to lower the voltage out, then life is much easier.
    Very briefly, a switching power supply operates with higher efficiency than a linear one. The linear supply uses pass elements that act like controlled resistances to maintain a constant output voltage. They have to dissipate a lot of heat. Switcher pass elements operate rapidly, and are on or off, minimizing losses.
    300 amps is still a lot to handle.
  7. aboamal
    Member
    May 29, 2008
    14
    you can use PMW circuit to regulate the DC voltage
  8. Jonnap2000
    Oct 7, 2009
    7
    It seems that the vehicle has two alternators that produce 300 A. Would it be feasable to that the regulation circuitry of the alternators and use them to regulate the external PCU. I know it is AC/DC for the alternators but would not be a case of removing the rectification stage?
    Who hard would this be?
    Many thanks for all your help.
  9. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Curious what kind of vehicle is it? Which military?
  10. Jonnap2000
    Oct 7, 2009
    7
    Sorry, i cant divulge that information. I know it would help if you knew but i may get into a lot of trouble.
    Sorry, but many thanks.
  11. MikeML
    Oct 2, 2009
    5,451
    1,066
    No, because to control an alternator, you only have to control the field winding. The current in the field winding of an alternator is usually about 1/20 to 1/50 th of the output current, so the vehicle's VRs are rated at most for about 15A.
  12. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Ok, so your military has no technicians or mechanics? :rolleyes:
  13. Jonnap2000
    Oct 7, 2009
    7
    They have but we dont have anyhere at the minute. I am only an vehicle electrician. Knowledge is power!!!
    Many Thanks
