DC Voltage indicator using dual/triple colour LED
Discussion in 'General Electronics Chat' started by lisahxw, Feb 23, 2009.
  1. lisahxw
    Feb 23, 2009
    Hi everyone, I am new here. Just wonder if anyone know how to design a DC voltage indicator using dual colour or ideally even triple colour LED, so it is function as follow:
    Vout<11V red
    {11V<Vout<12.5V orange}
    Vout>12.5V Green
    And anyway to make the reference adjustable.
    Thanks.:)
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    You will need two comparators.
    One that switches the red off above 12.5 Volts and
    one that switches the green off below 11 Volts.
    Greetings,
    Bertus
  3. lisahxw
    Feb 23, 2009
    Erm............ I thought using comparators need a reference voltage. But in this case, it is to indicate the battery voltage level and there won't be an other power supply. How could the circuit designed to "know" the reference voltage?
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    A comparator needs a reference.
    This can be a zenerdiode for instance.
    The other input will be the measure input.
    Depending on the inputs the comparator will switch on or off.
    Take a look at this page of the AAC eBook.
    http://www.allaboutcircuits.com/vol_3/chpt_8/3.html
    Greetings,
    Bertus
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    Use an LM3914 bar-graph LED driver IC. It has 10 comparators (use only 3 if you want) and an adjustable regulated reference voltage.
