dc voltage controlled oscillator, input voltage 0-1000mV
Discussion in 'The Projects Forum' started by gauravkalra, Jun 21, 2010.
  1. gauravkalra
    Jun 21, 2010
    hello everyone
    i want to make wireless FM temperature sensor
    sensor has dc otput voltage range 0 to 1000mV
    oscillator frequency required is near 100 MHz
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Here is something you can start with. See the attached .pdf document, look at the last page.
    You will need to use a faster IC, as the 74HC is limited to around 50MHz.
    You'll need to design a VCO (voltage controlled oscillator) for the input portion, as the existing design is controlled by a sensor with variable capacitance.
  3. Markd77
    Sep 7, 2009
    2,803
    594
    100MHz is in the band of FM radio transmission. Best check if you can legally transmit on that frequency in your country and how much power you can put out.
  4. gauravkalra
    Jun 21, 2010
    ya in our region it is okay
  5. gauravkalra
    Jun 21, 2010
    well thanks for your assistance
    i saw pdf and analyze the circuit
    i have some questions in my mind
    1 it is doing amplitude modulation or frequency modulation?
    2 while calculating R2*C2 time constant we get carrier frequency
    now if take C2 10pF and r2 is 1k then i get frequency 100 MHz but it written for only 10 to 50 MHz
    3 can fm band is possible?
    4 how to use enable pin inthe starting?
    5 it will give square wave output so can a square wave output is decoded at the fm reciever?
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I thought you said you analyzed the circuit?
    You forgot about L1 and L2. Use Wheeler's formula to get the approximate inductance
    As I mentioned originally, you will need a faster IC.
    Sorry, but your sentence structure reminded me of that image.
    As I mentioned before, you would need to use a faster IC.
    A logic 1 enables.
    A logic 0 disables.
    The L2/C4/C3/L1 network outputs a sine wave.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    See the attached for a rough simulation of the circuit.
    I decreased C1 by 90% just to make the simulation time manageable.
    The output is a gated 50MHz signal. This will be easier to construct and decode than an FM signal, as the base frequency would have to be extremely accurate.
